GAS IN Oil PLZ help
sparky52386ebay
Jul 15, 2004
Hemlock, Michigan
I recently just put my engine back together and i have gas in my oil everything in the lower end is new eagle rods ross pistons, bored .030 over with new rings. I have gas in my oil so it has to be something in the upper end. I have replaced my plugs with brand new ones. I dont know if it is my o2 sensor, ( i bought a universal one), or my fuel pressure regulator going bad, or something in my intake but all gaskets have been replaced except for the throttle body. PLZ help extended use with those conditions is bad for break in and cas cause serious engine damage.
thanks,
marc
1993 eagle talon tsi 2.0 turbo
stuck injector? if the thing sat for a long time, and there was fuel in the injectors, it can turn to varnish, and when the injectors fire, they dont close. if everything was put back correctly, i would look there. another possibility is fuel pump overpowering the regulator, and the injectors leaking, but they would have to really leak a lot.
the same thing happend to my car...i think it was because i have 550cc injectors and the AFC wasnt hooked up...is there any chance for my rings ...or are they already gone?????plz help
