Galant Evolution t-case in a 2g
Ineedboostman
134
6
Jan 20, 2010
Macungie, Pennsylvania
I have a trans and tcase out of a Canadian model galant evolution. From what I was old the final drive on this trans is different and would grenade my rear but I want to know if I can at least use the tcase ### it bolts right up to my 2g?
Potentially yes. The Galant Evo transmission has a different final drive ratio as well as the transfer case may have a different ratio, though normally, it had a 1.090 ratio. You need a 1991-1996 AWD 5-speed transfer case that has a 1.090 ratio otherwise.
To check which one you have, watch the following video and follow the instructions on how to check what ratio you have.
I dont think thats the video you meant to put up. Whats the name of it and ill check it out on youtube later tonight?
Sorry, you are looking to have 12 rotations of the output shaft in the input yoke of the transfer case to match up with the output shaft of the transfer case. To do so, you would mark a specific point on the input and output yokes so you can count 12 full revolutions of the input, resulting in the output matching your marked point.
The link has been fixed.
