1g transfer case in a 2g?
tim_korn_99
216
Aug 3, 2004
Bentonville, Arkansas
Hello,
I've come upon a transfer case that is for sale dirt cheap. Its out of a 1990 GSX. will that work in a 2g car? If it will, i'll buy it to keep as a spare, seeing how my luck is now days...
Thanks
-Tim
dont think so, different spline count on the earlier vs later transfer cases. (26 vs 27?)
Good thinking tho, can never have too many extra transfer cases on hand when one eats shit.
Doing some extensive searching on here, and some other sites, i think i understand what's different. I'm pretty sure that mine will be a 23 spline count. and, so is the transfer case that im looking to buy. BUT, i think on the 97 and up cars, that the gearing is different inside the transfer cases. so, even though it will physically bolt up, it wouldnt work. or would it? im still not 100% sure, maybe someone can confirm this. I'm still gonna purchase it because it is so darn cheap. and maybe it will come in handy one day.
You have a 97, it'll be a waste of money.
The drive/driven gear is pretty much all that consist of the t-case and that is what differs from the pre-96/ 97+. So unless you want the outer casing,bolts and nuts dont buy it.
Buying an auto t-case would be more benificial than that. It's got the same gear ratio(1.074) as the 97+ 5spd tcase = same P/N drive/driven gear if you can rebuild your own.
-treebonker
Sorry, but i dont know the model number of my transmissions. Its a 5 speed... I'll email Jon at TRE and see what i can find out. Though, im pretty sure that if the eclipses changed in 97, that the talons did also.
Thanks for the info though
-Tim
