Galant 4G63 ECU swap
azgalantgsx
Nov 16, 2008
Flagstaff, Arizona
my car was a n/t car but now it has a turbo (galant gsx) can i use a turbo ecu or any 4g63 ecu?WTF
yes no maybe??? can i use a evo 2 ecu?
Thats a good question. If i had to guess, it would be no. I would suspect you would have to use a standalone or piggy back ecu. The car was wired for hot having a turbo, and im not sure it would accept a turbo ecu. Similar to a N/T in the way you cant just through a turbo ecu into it. However, if the car was a vr4 and you were putting in say a eclipse turbo ecu, then it would work. Sorry for no clear cut answer.
James :laser::talon:
You'll have to look at the 1G NT to Turbo swap articles and then check to see how much applies to you.
In general once to take care of the wiring differences the ECU plugs right in.
http://www.dsmtuners.com/forums/articles-engine-fuel/37019-installing-turbo-4g63-into-nt-4g63.html
http://www.dsmtuners.com/forums/articles-miscellaneous/220179-easy-non-turbo-turbo-swap.html
http://www.dsmtuners.com/forums/art...stor-pack-wiring-1g-n-t-turbo-conversion.html
There are also several articles on the GVR4 forums specific to the GGSX to GVR4 conversion.
