fwd: Clutch issues, sleeve hosuing
dskagr
46
46
Feb 7, 2011
209/408, California
So, I got around to getting the engine together. Car starts, great!
On attempt to driving it though, I noticed that the gears wouldn't go in. Duh. Forgot to adjust the clutch rod. So I adjusted it according to Jack's videos. Gears go in pretty well now, so that's a plus.
Now, the clutch engages way to quickly. In first gear, as well as reverse, a slight raise of the clutch from the floor gets the car going. I tested to see if it was dragging by putting it in first, clutch to the floor, and revving... Well to my disappointment the car inched forward.
I have the South Bend Clutch DSM SS-X Clutch Combo, with a ACT streetlight.
So, I was thinking maybe the flywheel wasn't stepped correctly. ( Never checked it:ohdamn: ) Time to remove the tranny!
So now it's off, and I notice the input shaft housing has skid marks (LOL) :barf:
So took off the bearing, and it actually feels somewhat warped on one side. Not too much, but noticeable running your finger over it.
Would this cause my clutch issues? And also, would it be reasonable to try smoothing it out with 600 grit?
That's the thing, even when I did according to this post, http://www.dsmtuners.com/forums/articles-drivetrain/213503-how-properly-bleed-your-hydraulic-clutch.html, it still did the same thing. So I went ahead and replaced the slave and master, readjusted it according to jacks videos, and followed those instructions to bleed it again.
That's what led me to believe it was an actual clutch issue rather than hydraulic. I'll make sure to bleed it, tons, when I put it all back together.
But as to the sleeve, can I smooth it out? Would it be safe to do so. I'd rather not have to replace the whole bell housing. :/
Maybe the better question would be, what caused it to warp at one side and could it be a helping cause to my clutch issues?
Yes, smooth it out. Certain throw out bearings seem to do that; OE units are highly recommended. Be sure to grease the sleeve when installing the new TOB as well.
  • Wanted 6 bolt NT water pipe
    • chrisman287
