Fully built 420A part out
SoCalK61000
143
Dec 25, 2011
Riverside, California
AEM tru boost. $230.00
Wideband. $160.00
Fuel press. $135.00
Oil pressure. $135.00
Oil temp. $125.00
Or all for $715.00 with the pods
Turbo kit with piping, intercooler, bov, wastegate, manifold, injectors, fuel pump, couplers, oil feed line, oil return line, all with black AN fittings and down pipe. All piping powder coated green. $1,350
MegaSquirt MS2 with 3 bar map sensor voltage regulator and wire harness. And if it will transfer over to a new owner i have a full tuner studio license $525.00
Bride racing seats with brackets to bolt into a 2G. $600.00
Evo brembo's custom powder coated green with KMV brackets and the proper machining to the spindle for upright placement, with rotors, pads and a brand new 3rd gen master cylinder $600.00 +stock brakes
Complete built 420A engine weisco pistons, eagle rods, acl main bearings, clevite rod bearings, nitrited crank, crank scraper, new oil pump, new water pump, gates Kevlar timing belt, ARP head studs, ported and polished head, sure tech SS valves, dual springs, titanium retainers and crower stage II turbo grind cams, msd wires And a spec stage III clutch. Oil changed at 500mi then 1,000mi then again at 4,000 and 7,000 and is sitting just a bit over 7,400 miles on this engine right now. $1,750 plus your stock engine and clutch
The rims have a good size curb mark on the passenger front and a smaller one on the rear. They are 18's and less than a year old tires have about 9,000mi on em don't really care to sell them. $750.00 plus stocks.
