For Sale Full Partout List 90 AWD DSM
Artofschiffy
70
7
Mar 12, 2017
SFV, California
After starting a new job after college and with the loss of room to work on my car, I am parting out my project. A majority of the parts listed have less than 150 miles. Please feel free to make offers, package deals are preferred. If you're inquiring about any part, I'd be happy to provide great detail on condition, as well as provide photos. There are a lot of other stock parts I have available so feel free to ask if you need anything. I will also provide new/used gaskets to parts your purchasing if I have them. Some of the parts listed are still installed in the car so please give me a little time to uninstall your requested part. shortblock is still assembled and is in great condition. Head components are also assembled. I'm located in Southern California. Call/text anytime (818) 456-9848.
lightly ported Evo 16g w/new OEM wastegate mated with a FP ceramic coated exhaust manifold, ARP and FP hardware and gaskets SOLD
FP ceramic coated exhaust manifold SOLD
new China ss o2 housing
90 NA Throttle Body with tapered/polished lip
Stainless turbo oil feed line
Stainless remote oil pressure line
90 Relocated oil cooler with -8AN lines
Relocated power steering cooler
Prothane front, trans and rear roll stop motor mounts
92awdgsx coolant overflow tank
FIC 1050cc Low-Imp Injectors SOLD
New ARP head Studs
ARP intake manifold hardware
ARP exhaust manifold hardware
shortblock:
6 bolt 2.0
86mm CP pistons
Manley H-beam rods
Eagle crankshaft
Kiggly main girdle
Cometic head gasket
King XP Tri-Metal main and rod bearings
ACL oil pump
GSC race balance shaft
head (sealing surface flake near coolant port):
Supertech dual valve springs with Ti retainers
1mm oversized black nitride intake valves
Inconel exhaust valves
Updated lifters
Viton valve stem seals
HKS 264/264 camshafts
Gates racing timing belt
Fluidampr harmonic balancer
Thermal intake manifold spacer
ECMLink with 90 fed ECU purchased from ecmlink SOLD
Innovate LC-2 Wideband SOLD
AEM Boost
AEM Oil Pressure 150psi
Competition Clutch 4 puck clutch
Competition Clutch 2700lb. Pressure Plate
Competition Clutch Stage 3 Ceramic Disc
Competition Clutch Flywheel
Competition Clutch Forged Clutch Fork and Pivot Ball
OEM Throwout Bearing
OEM Master Cylinder SOLD
OEM Slave Cylinder (restrictor removed) SOLD
Stainless master to slave line SOLD
91-94 awd NPXV transmission purchased as a Shep stage 2
90 awd trans
22 spline transfer case
23 Spline transfer case
91-94 shifter assembly
Hyundai timing cover
Aluminum 2 row radiator
Battery relocation box
1G stock intake manifold
1G stock MAF
Evo 8 Maf
1g 90 to evo 8 maf connector
Stock injectors
KYB GR2 front struts on stock springs
ES front control arm, subframe, sway bar, and crossmember bushings
Moog sway bar links, ball joints and tie rods for LCA
Rebuilt power steering pump
Rebuilt rack & pinion
Goodridge ss brake lines
GST rims with tired (95% tread)
unfinished 3” vband exhaust
Cyclone intake manifold SOLD
Valve spring removal tool
