Fuel Rail Help
slammeddsm98
Jul 13, 2006
Xenia, Ohio
I own a 98 gs, and i am doing a rebuild on my motor for more boost. I have all the mechanical stuff but i am having a hard time figuring out what to do for a fuel rail. I have precision turbo and engine 680cc injectors. Is there an aftermarket fuel rail for the 420a?
Can I use the stock one? any help is greatly appreciated.
How much boost are you planning on running? What do you have in your car? More info is needed to fully help you.
I plan on running 10-15 psi, for now, i have je pistons, eagle, rods, fmic, t3/to4e, safc2, aeromotive 1:1 fpr, dual stage manual boost controller that will be set at low-10psi and high-15psi, i may increase boost later down the road if i do head work, that is why i got 680cc injectors.
In all my "popping" around on the web I've never noticed an aftermarket fuel rail for the N/T, but then again I haven't been looking for one. However, I imagine the fuel rail will be the least of your problems, especially at 15+PSI.
Thanks a lot. I'll try the stock one. I was thinkin about pickin one up that was made for the 4g63 motor, because i've heard that you can use stock gs-t injectors in the 420a rail.
