OBX fuel rail help
eoseitz
148
Jun 16, 2008
Marion, Ohio
I've looked around on here but I can't seem to find an answer to my question. I've found information on how to install the OBX fuel rail. However, will a fuel rail for 95-99 work on my 1990 laser rs. I'm assuming the fuel rails are the same, but I wanted to check before I bought it.
From my memory, the main difference is inner diameter, 1g is a little bigger, I don't believe there are any other differences, but I could be wrong.
"This is a Used Fuel Rail for the 2G Turbos. These are very similar to the 1G Fuel rail, just a little longer. 1G Fuel Rails should work, but they do not have the injector clips."
That's from DSM Graveyard - Your #1 Source for Used DSM Parts!
My guess is it would work.
