Fuel Pumps What to get
Wheels-a-turnin
225
Apr 1, 2003
troy, Michigan
Let me explain my situation. I have a built 6-bolt in my 2g that will have the SFP Manifold, t3/t4 60-1 .63 a/r hotside, with 750 injectors.
Now with proper tuning of the AEM this setup should not have a problem getting into the 500whp range. In the future for track use only i am hoping to be running a descent size shot of nitrous somewhere around 75 to 100 putting me into the mid to high 500whp range.
Now heres my question, i have heard lots of great things about the Walbro 255lpr high pressure, but is this going to be enough for this setup and hopefully the setup in the future, i have seen others from aeromotive that will support my dreams. What are your opinions, contructive critism is welcomed.
255 hp is fine. if you ever out flow that, you can get an additional inline. i honestly dont think youll be getting the #'s you hope for out of your 60 trim, so 255HP will be good for you.
happy boosting.
the 255 should be fine. but i don't think u are going to get the numbers u are looking for. if you think you are goin to push that fuel pump to far you could always go cozmo. its a lot more expensive but u won't even need more than that. good luck
