Fuel pump wont turn on
cRaZyCastroGST
Oct 3, 2010
Billings, Montana
So my car hasn't started in about 6 months. And the last couple times it did start it took forever to fire up. So when i finally got around to check it out i realized my fuel pump isnt turning on. So I put 12v to the fuel pump bypass wire on the firewall and i can hear the pump kick on. I then removed the fuel pump connector and turned the key on and i get 0v. So i decided to replace the MFI/MPI relay with a new one, but it did not solve my problem. Next I checked the voltage on pin #8 the red/white wire and it shows 11.??v with key on, and pin #38 on the ECU shows 11.??v key off and .6v key on. So Im kinda confused on where to look next???? Any comments or suggestions would be appreciated!!! Thank you.
