1G fuel pump relay
aaron207
Nov 24, 2009
Rumford, Maine
okay so im wiring my fuel pump up and i cant figure out where to wire these 2 wires that come off my relay in my hatch theres a ground and a power then 2 wires that hang under the car toward the pump and idk where they go to? any wiring diagrams or pictures ive looked for a couple weeks and cant figure it out
find the correct 12v power wire that goes to the fuel pump, that will be used for two of the pins on the relay
stock 12 v power to fuel pump[ RELAY] Ground ( symbol for this will look something like -[//]-
then you will take the the other half of the stock wire that you cut the one of the remaining pins
and another wire from the battery to the last pin on the relay.
the symbol for this looks something like -[_/ _]- ( like a switch )
you can also rewire the ground for the fuel pump but i personally never have.
I also ended up using the rewire in the panel on the driver side of the car.
