jazzyjay
- 215
- 0
- Mar 27, 2003
I thought my problem was with my injectors. So I had them replaced with 950cc injectors, but the problem persist. I have a 255 GPH fuel pump, 6an fuel line from the tank forward Mr gasket fuel filter and Kirban fuel preasure regulator. I currently have my base fuel presure at 44psi with the vacum line off. I have a 60-1 turbo at 15 psi of boost the car is running out of gas. I can adjust the afc to the max and the car still running lean. I swapped the filter for a new fatory unit but still the same results. I will pull the fuel pump tonight to see if the screen is dirt. If anyone have any suggestions please post
