Fuel pressure!!
screamin talon
34
Mar 2, 2003
douglasville,
i was wondering how much fuel pressure my stock regulator puts out on my 97 GST. i was lookin at getting the BM FPR but didnt know what to set it to once i got it , or if it would give me a lil bit more fuel even though i still have stock injectors??
list of mods>>>
greddy evo exhaust
apexi GT downpipe cat elim.
injen intake
greddy type s
ngk iridiums
ngk wires
255 walboro
FP 17 psi actuator
greddy profec E01 boost controller
greddy hardpipes
gixrman said:
The B&M unit is only good to riase your pressure.
Thats not totaly true. While it will not drop your fuel pressure a lot, it does have the ability to drop it a little bit. The fact that you can screw it out farther and let a little more pressure off the spring vs. stock will allow for a 3-4psi drop in fuel pressure, but that is it.
Since the 255 is likely causing FPR overrun and since the B&M reuses the stock FPR internals then it's still overrunning because the stock return port can't flow enough fuel wide open to alow pressure regulation.
With a pump that isn't overruning the return port I'd grant you that the adjustment on the B&M might give a small margin for reduction.
