Fuel injector ?'s
whiteboyz
244
Jul 21, 2009
Albany, New York
Ok so everytime im at the junkyard, i see cadillacs and a few other cars with exact looking injectors as FIC and etc. My question is how could i find out what size they are before i buy them and waste money ? or even if they would even work in my dsm. thanks for anyhelp.
Do some google searches for those cars you are seeing and find out what size they are.
yeah I try'd that but i did not get any cc's info or lbs info just part numbers and such. i will try and run the part#'s i got from them
DSM injectors are honestly quite large by stock standards so it is fairly rare to find compatible injectors that are bigger than our stockers. Beyond that you also need to know that they are low impedance or modify the car to deal with that.
One very notable exception is CNG injectors. If you ever find a Crown Victoria, or heavy duty Chrysler/Ford truck/van that ran CNG for a fuel then check the injectors because assuming you found the right vehicle they are 1600cc low impedance injectors with ev1 connectors and with only slight modification can be used in our cars.
