Fuel Injector Problem!!!
ALLeyesONmyGSX
138
Jun 9, 2004
Los Angeles, California
hey guys i was installing my new injectors and the plastic bump stop that guides the bolts from the fuel rail fell somewhere into the engine bay... they are lost--- now when i finish, i crank the car and it just crank's and dies--- is there any advice, are those plastic bumps needed ? thanks ... :dsm:
yea you need those.theyre fuel rail spacers and they keep the injectors and the rail in place.with out them,your rail just bounces around and is a big fire hazard.find those spacers asap.
wow, this same thing happened to me today, lost an injector down there too:notgood:
took me an hour to find them all, they were laying down at the bottom of the intake manifold.
you need a hella bright light to see them, i ended up fishing them out with a piece of wire(hands dont fit down there)
on a side note got them installed with no leaks along with my dsmlink:thumb: :talon:
I've dropped one before when putting new injectors in and I would recommend that you get a new set. These are available from the dealership (fuel rail spacers is the correct term) or you can buy them from SBR as they have them in stock.
I rigged something temporarily and used my existing ones on the outside, but you may not get an optimal seal at the rail and encounter a boost leak from that location. Get a new set, use some RTV and set them into the head so that you don't have to worry about them falling off again.
