Fuel and spark, but no fire
spooln4fun
642
14
Jul 9, 2005
BELPRE, Ohio
Alright, i did a turbo conversion, to a n/t motor, everything was rather fine and dandy the other day i could start it, i let it warm up. now nothing. It rolls over like normal, its getting spark, there is fuel in the fuel rail, and the plugs are brand new. Any ideas as what it would be? Can that injector resistor pack go out? It was only held in by one bolt instead of the two as it is on turbo models. could i have fried it?.
Thanks Matt
Everything is in time, air seems ok, i did happen to put a n/t computer in today, the the damn thing started up, but runs real bad, do to smaller injectors. So hopefully i get a turbo comp. and be good to go, i do thank you two for the help.
DAmotorsports said:
If you have fuel and spark, there is only 1 element missing and that is air. So I would check the turbocharger, MAS, etc....
It's fuel, spark, and compression. No compression=no start
