Front & Rear Cover assembly question
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I'm installing the front cover on my new 2.4 block I have the gasket that goes there, my question is do you use any type of silicone as well to keep it from leaking oil. Same goes for the rear main?
What gastket are you talking about? The seal for the crank, or the actual gastet for the mating surfaces of the front case and rear main. The front and rear main seals, along with the rest of the rubber seals just need a little oil around the lip. As far as the gaskets, use some copper spray. They dont need rtv.
This is on a 2.4 6 bolt there are paper gaskets that mate the cover to the block. I know how to install the seals just wanting to know about the case to the block. So copper spray is the best solution for these. Should i spray both sides of with copper spray or just the block side?
