front o2 low at idle
justin0469
1,004
10
Apr 4, 2003
san diego, California
So I'm just gettin into tuning but this is my problem. My front O2s cycle normally cruising at highway speeds. But when at idle, they are low, around 0.02-0.03V. I've raised my fuel map up to 5% more at idle but doesn't change anything. Do I just have to keep going until it pushes it into the closed loop or is it something else?
Also, I get at most 0.23V of knock throughout the RPM range, is this something to worry about? What is the voltage range for the knock sensor?
What are your fuel trims like? I didnt have o2's at idle for a while either. I reset my ecu. I started getting o2 cycles at idle now. Also I replaced the mas since I have a 1g, those mas are so cheap. I did that a month ago, and everything seems to be reading fine on the logger.:thumb:
Ya I meant to post the fuel trims, they both show as 0% if it had to take away fuel it would read negative and more would be positive right?
Also, base timing is supposed to be 5* right? at idle mine bounces from 9*-12*
This may seem like a stupid question, but one that needs to be addressed none-the-less. Have you checked the front o2 sensor to make sure its not shot. From what you described it seems that its reading decent when there is a sufficient amount of exhaust flowing(ie. cruising), but when there is minimal exhaust flow(ie. idle), the sensor is not reading as well. I would pull the sensor first, if it looks white and chalky and hasn't been replaced in a while, that could be the culprit.
I had not thought about the exhaust flow effecting the operation of the sensor but that does make sense. I will check it out
