Front Motor Mount
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
ok Is it ok for me to not use my front motor mount (roll stop mount)? Reason is my current setup will not let me bolt it on there because the top of the mount flange (where it bolts to the motor) and the bolt make contact on the turbo.
If it isn't a good idea to drive without it. Do you think I can cut off the top half of the mount. Then have a piece of 3/8" steel welded to the bottom of the mount (for reinforment). That way there is only one bolt on the mount that bolts to the motor instead of two. Or use a strap, chain or possibly an torque damper to replace the mount?
