Front end squeeking noise
1killertsi
Aug 24, 2004
Pittstown, New Jersey
Just in the past few weeks started a loud sqeeking noise when going over bumps and when turning. You can sit at a dead stop turn the wheel back and forth all the way and it will make the noise but will go away if you continually sweep the wheel back and forth. I replace the sway bar bushings due to alot of play in them but didnt do anything. Could the sway bar links be shot?any help would be appreciated. thanks
Rich
I'm having the same exact problem but mine seems to go away when it rains or when i wash the car. and when it goes away it usually goes awy fo about a week I wounder what it is
Yeh it does go away when it rains. I found the problem though, its the lower ball joint. The boot ripped and there is no more grease to lube the joint. I ordered a brand new lower later arm with joint for 70$.
