Front caliper sticking, no brake pressure
LoneAvenger
Aug 24, 2014
Phoenix, Arizona
This is a 97 dodge avenger, 420a 5 speed
First off started with passenger side caliper grabbing/sticking, rebuilt caliper and guide pins, brand new disks and pads for both sides and bled it. Then found out hose was bad so I replaced the hose then bled again. Drove it out of the drive way and the passenger side is still grabbing? The wheel hub looks old but no noise or movement from it. Theres very little brake pressure too, I hear the rear drums working but very little in front.
Theres no leaks anywhere and ive rotated the tire while its suspended and it rotated freely. When engine is off the brake pedal will get hard after a couple pumps but feels weak. Like I can almost reach the floor while pressing on it.
Is there a way to check master cylinder without replacing it?
inner/outer tie rods and sway bar links are also brand new and none of the control arms pop or have any cracks in the bushings
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
