fried dmbc
Hiitman
482
3
May 12, 2004
Colorado Spring, Colorado
i was wondering if this was possible. ive got a dejon dmbc. i had it mounted on the far left fan mount. heres the problem. i had it set at 18psi. after a couple weeks it jumped up to 22psi. ive got both screws turned completly out and it still wont go down. i took the dmbc off and im just running off the wastegate spring (10psi). i was thinking the problem could have also been the autometer gauge. im now running defi gauges but havnt hooked the dmbc because i want to get my fuel trims and a/f ratio set at a low psi. anyway. could too much heat fry a boost controller?
Unless the heat caused a spring to seize somehow, I do not know how heat can affect an mbc. You sure a vac line did not blow off somewhere?
fairly sure. running the wastegate to the turbo holds a steady 10 psi, which is the spring in the wastegate.
MBCs have a bleeder on the output side, so even when set to full soft, they raise boost a little.
But not 8 psi.
If you have a MitiVac and a spare boost gauge, MBCs are easy to test. You are looking for repeatability. Anything that doesn't open at the same point ten times in a row is trash. Use the hoses from the car for the test, because that's the set-up you can about.
- Jtoby
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
