free ems
brandonclum
136
May 20, 2009
spokane, Washington
I have heard that there is a free ems software that is used on dsms. does anyone know where to find this software and has anyone used it with success before?:confused:
If you have an eprom ecu you can:
Have the ecu socketed -$60
Chip burner-$40-100 or if you have laptop you can get Ostrich emulator-$175
Tunerpro can be used with burner- $free$ or Tunerpro RT with laptop for realtime editing
DsMap(Jackal) is also an option if you opt to go with the Ostrich for speed density conversion
If you go with a standard chip burner, there are speed density files, which i use, in the DSMEcuYahoo forums if you don't have a laptop
Logging can be done with MMCD(free) and a palm(cheap used) with cable for 1g($30)
You can also use EvoScan if you have the laptop for logging which is not expensive
