yoshimitsuspeed
- 674
- 5
- Jul 17, 2004
portland,
Oregon
So I recently got a MK1 MR2 and have started hanging out with the local MR2 guys, one of which is a cool toyota mechanic. This guy loves to do cool swaps like putting the 2.0 and 2.2 MK2 engines in MK1s and 3.0 and 3.4 V6s in MK2s. Naturally discussion has come up about making an AWD MR2, specifically for my interest a MK1. Now there are several problems with this aside from the fact that it would be a lot of work. The biggest problem that I see is a transversly mounted engine with AWD will send the drive shaft out the back of the car. If you turn it around you will have 5spd reverse and one really slow forward.
Well now we get to why I am postin this on tuners
It occured to me that since the evo 4 and up is mounted reverse the engine should also spin the opposite direction right? I also assume that the engine being a 4G63 should bolt up to a DSM tranny pretty easily right? Now the motor would be spinning the tranny backwards so theoretically if you turn it around and point the driveshaft at the front tires it should drive in the proper direction right?
Now thinking about this a little more it occures to me you will probably at least need straight cut gears since I am assuming it would not shift properly spinning backwards. With straight cut gears would the tranny hold up to reverse rotation? If so will the center diff be a problem? This is just fanciful thinking right now but it seems like one of the simpler solutions that I have thought of so far.
