FP with hoses connectes
szewczyd
792
Aug 31, 2003
Oconomowoc, Wisconsin
I have a 2g and I have heard that the fuel pressure should be 43 with the vaccum hose disconnected. What hose do I need to remove, or what should my fp be reading with everything connected? Also is there any reason that the fp should be higher or lower?
Thanks
Doug
The hose to afpr and plug up the nipple on the afpr. This should help clear things up a bit, read the whole thing. It will show you how to set your base setting later in the article. Good luck.
