werid problem with hoses.
lilpastrana
53
Oct 30, 2005
centuria, Wisconsin
so i have had a coolent leak for a little while now and i fixed the leak now my car gets to much pressure and blow a hose off and if i dont blow a hose off i will pop a hoae this happen to my both of them. So now i have thought it could be the thermostat or head gasket leaking and pressusing the lines so make them burst.
What are temps when this happens ? I would eliminate small things first . Thermostat , easy fix . Could be a water pump , difficult fix . Can you feel coolant circulating in hose when you start car ?
the temp is right in the middle where is should be and if you you take it easy dont go above 3 grand it is fine but take it to 7 some times and it will blow the hose and heat up then i will shut the car off.
