FP Green, what supporting mods are needed?
kristmen
572
3
Oct 26, 2002
Southwestern, Michigan
I wasn't sure what forum to post this in so if this is the wrong one, I'm sorry.
Just a quick question about FP Green turbo's.
What supporting mods would be needed to run this turbo on a 1G? My friend said a built engine and like 720cc or bigger injectors and a FMIC would be needed. Is this correct?
I currently have a Big 16G, 550cc's, AFC2, MAFT blow threw setup on a stock SMIC, Walbro 255 so on and so forth.
What would be a basicly setup that would work ok with an FP Green? I dont want to spend tons of money to make it work.
Car is an A/T btw.
i'd definitely get a fmic. Running the green on the stock smic would suck. You could use your 550's, but keep your boost a bit low until you can afford bigger injectors. You dont need a built engine or 720's(660's would suffice for most) but those things would always be nice to have.
Well wouldnt it be pointless to keep the boost low if i was going to buy this turbo anyway?
I mean I know it out flows a big16G and its more about CFM then psi of boost but with a low boost setting wouldnt the CFM be greatly reduced anyway?
I understand that is just until I got a FMIC but I'm starting to think it might be more expensive then I can afford is all.
