forward facing oil filter housing
Ive done some research on this topic bc i have a forward facing ofh myslelf. I've came to the conclusion that you basicailly dont port anything until you know what your oil pressure is after the start up and break in of your motor. You dont want to port your ofh when you dont know what the base oil pressure of your engine is. Once you have figured this out than you can port your ofh if it's needed. Hope this helps.
