1LE
- 1,347
- 4
- Aug 1, 2002
Sylvania,
Ohio
Before I go to all the work to try and figure out how...
Has anyone found a quick hack to make the ECU think that the A/C is on (when it isn't)?
My car finds the stock 750rpm to be just a bit low, easy to stall... The extra 100rpms from the car thinking the A/C was on would make it a lot easier to drive around town. I don't actually have the A/C anymore and don't mind cutting wiring. I'd expect there's a pair of wires I can short somewhere that will make the ECU think the A/C is on without actually attempting to engage the compressor or check the pressure sensors and switch positions.
Has anyone found a quick hack to make the ECU think that the A/C is on (when it isn't)?My car finds the stock 750rpm to be just a bit low, easy to stall... The extra 100rpms from the car thinking the A/C was on would make it a lot easier to drive around town. I don't actually have the A/C anymore and don't mind cutting wiring. I'd expect there's a pair of wires I can short somewhere that will make the ECU think the A/C is on without actually attempting to engage the compressor or check the pressure sensors and switch positions.
