Fog Lights REMOVAL
ARTSUPRA
110
Feb 13, 2004
Vancouver,
Well I just received my set of H4 and H3 Sylvania pure white bulbs.
So I changed the head lights no problem, but as soon as I got to the fog lights it a real pain. I tried 5 different philips screwdrivers, even my friend tryed to take those dam bolts, anyways we end-up stripping the bolts with no results.
HOW DA HELL I SUPPOSE TO REMOVE EM?:thumbdown :mad:
I figure I can pull the whole foglight assembly and work it on a bench, but is there any other way?
ART:mad:
After I stripped mine I just drilled those mothers out. Good luck removing the bracket before the lights, it won't be easy and may not even be possible without tearing apart the intercooler ducting.
Just drill the lights out and leave them out, better for intercooler flow anyways.
hahaha that's a "me too" problem because that happened to "me too" when i was removing the one in front of the intercooler.....i was able to remove one screw, then just pryed, and pulled, and twisted it till the plastic was all FUBAR on the foglight then just got a pair of pliers and pulled, it still didn't come off so i was able to flip it around, and pull it out of the way to give me enough room to just unbolt the hold down for it and it's in the garbage now.....man it sucks....just get a drill with a titanium bit and drill the screw out
