Fog light install
Dnice11
58
Aug 12, 2009
Philly, Pennsylvania
I brought a set of fogs for my 2gb eclipse and im have a little trouble installing them. Mounting them is the easy part. I wanna go the same route as K dogs post but im confused and having trouble on how to wire them....
I have a N/T 97 eclipse myself and installing the fogs are pretty tricky with the limited space the bumer gives you. Wiring it up isn't that bad though, if you've got some solder and a heat gun you can do it the right way or if you want to hook them up really quick then you can always use a little electrical tape and splice the wires together. There should only be one wire to splice and once you've got it taped just reassemble it and test it out before mounting it.
I seen a fog light wiring harness in autozone and a h3 wiring harness on ebay and I think I can get it to work. With the wiring harness do I need a relay because the autozone one doesnt come with it??
