Flywheel
Talon7038
71
Feb 24, 2013
Pittsburgh, Pennsylvania
Ok I have done some searching and get mixed answers. So my question is. I have a 6 bolt swap happening and looking for a flywheel will a 2.4 flywheel fit the 4g63 if it is awd
Assuming you mean a flywheel from a 2.4L Spyder -- that is a 7-bolt, much like that found in the FWD 2G turbo models. No, it will not bolt up to a 6-bolt. You'll need a 6-bolt flywheel to bolt up to your engine block and an AWD flywheel to fit in your AWD bellhousing.
