fluxuating idle.....
92dsmgst
92
Dec 9, 2008
Streetsboro, Ohio
When i start my 95' talon TSi the idle is normal most of the time but after warming up the idle will fluxuate higher and higher ( starting at 2k all the way up to some times 4k). I pulled my throttle body off and check the IAC and replaced my TPS and adjusted it right( i think). I cleaned the throttle body spottlessly. When the problem still presisted i cleaned my MAF and MAP sensors. I sprayed starting fluid everywhere and couldnt find any vacuum leaks. I am replacing my turbo soon because mine has a ton of shaft play but when i install it i am going to do a boost leak check, i just dont see this being my problem though. Any ideas?
