Fluids amount help
18Ace18
107
Apr 24, 2010
Hialeah/Miami, Florida
2G-6-BOLT
I need to know how much fluid do the following use..
Transmission
Transfer case
Brake fluid (what type)
Power steering fluid (what type)
3 quarts for the transmission, gonna need to buy one quart for the transfer case but it wont take the whole thing, just make sure you remove the bolt on the front of the transfer case and when the fluid starts to come out from it you are good. DOT 3 brake fluid will be fine as long as your not racing your car everyday. You could flush your system and run DOT 4 it handles heat a little better. The manual suggest that you use Dexron II power steering fluid. I don't know how much of it you will need for the brakes and power steering fluid.
2.4 in the trans. Or a general rule is to fill it up until it's coming out of the top.
Transfer case is 0.5 qrts.
The differential is 0.9 qrts.
I suggest Red Line fluids
