dsmkid4g63t
- 77
- 0
- Jan 31, 2006
Cumberland,
Rhode Island
Hey guys whats going on? I am just looking for some good opinions on what to do with my motor. I have a 2g talon. I bought it with a broken stud on the exhaust manifold, finally got the time to take the manifold off and inspect the head and broken stud. Turns out there are 2 broken studs...someone attepmted to drill them already, another thing is there is slight head gasket seepage right behind the manifold (and yes its headgasket). Im just looking for opinions on what to do. If i pull the head and swap out the head gasket, arp head studs, new timing belt, tensioner, balance shaft belt and balance shaft tensioner and water pump (car has 130k so i should do them all) im looking at close to $500 in parts. I was planning on doing a 6 bolt swap sometime in the next year or so, do you think now would be a good time to swap it out? Or should I fix the 7 bolt and wait on the 6 bolt?
Also whats a good guestimate on the final costs of a 6 bolt swap....
Thanks for your opinions guys.
ill just have to re-arange my want list.
