Fix alignment dowel pin in block?
jemsoccer
316
3
Dec 17, 2006
Ohio
Long story short, the backside dowel pin and bolt hole, that aligns the transmission to the motor, was drilled out by the previous owner. He had snapped a bolt off in the transmission and simply drilled and tapped a much larger bolt in that location to fix this (through the block and into the trans). My question is, after welding this hole closed in the block, how do I locate the exact position of the stock hole? Is there some way to align the transmission shaft and crank, then drill the hole?
I have access to a machine shop (g/f's dad owns it) and have an extra bell housing that can possibly be destroyed to use as a guide. Please let me know if anyone has had experience with this and ideas on how to fix. Thanks.
How accurate does this need to be? Thousandths, hundredths, or just dam close? I also have a buddies block sitting next to it that has the pins in it that I could make a template from. But I need to know how closely this needs to be machined.
the starter plate bolts to the block behind the flywheel.. if you can get 2 bellhousing (top ones) bolts in and get a dowel in the other side, it should give you a perfect template to go off of.
Good luck!
Good luck!
I have thought of this, however, the bolt holes to the top are not very tight, there is some play in there. Which brings me to my question on how precise this hole needs to be.
