First Log EVER! What am I looking for?
SubversionX
241
7
Jan 8, 2010
Virginia Beach, Virginia
So I finally hooked up Link and got a log in neutral, just revving up. I'm trying to find either a base tune to save to my ECU, or better yet, to figure out what I need to change to make this graph look better. You can see around 4500rpm that things start to go crazy, and everything sputtered as though I had blown an IC piping off. Still learning the ropes and trying to figure things out. What can you all tell me about this log?
Or go to ecmlink's web site and watch the tutorials on setting up idle and cruise tune, but first make sure everything else in in spec, thottle getting full travel, tps adjusted correctly, temp sensor in working order, isc is working and biss adjusted properly, spark plugs are proper temp and gap and no boost leaks all before you start doing your tuning.
Your airflowperrev is a little high... need to get it around .24/.23 ... so your injectors/maf settings might need to be tweaked a bit. your front o2 is pegged at 5v, and your cooltemp isn't reading. I'd def look into those things first, and get them fixed. do you have a wideband doing narrowband sim? or just a normal o2?
