first datalog with evo scan, how does it look?
M1L3S
132
Apr 1, 2012
maple grove, Minnesota
:confused::ohdamn:[
hopefully this loads, this is the 15 psi pull
2 step
did i log things right? is my tune horriably wrong?
im a complete newb, i wanna know if i can run at least 20 psi?
i had the car tuned but had to stop because of fueling issues, i fixed fueling issues i think, just wondering how it looks from a pro
-5* timing at 5k rpm? Ok number one, your request numbers for knock is wrong, you are going to be knocking like a mother goat. If you are pulling all the way to -5* timing i'd immeditly turn the boost back down to 10psi and fix whatever is wrong.
woops looked at the 2step log.. The actual log isn't great either.. 6* timing is terrible. You should be at 17* by 7k rpm.. You need to make pulls to 7k rpm. knock sum is still ###### wrong.
