First datalog, howd I do?
PieEyedPiper
DSM Wiseman
5,580
65
Nov 13, 2004
North Bay Area, California
I know theres more info than needed, but i figured I may as well be on the safe side.
I'm having a rough time deciphering whether or not this is a good result.
Thanks!
looks like you are knocking and getting some timing pulled. It looks like you are running a little bit rich too.
EDIT: oops, was looking at the wrong O2 bank. Looks like you are a little bit on the lean side
Thank you very much. I'm pretty much stock.. so all I can really do is replace my fuel filter and try a run with a full tank of gas next time.
Any other suggestions or input is appreciated.
Thanks you guys.
Btw, I'm from BC. GO CANADA! :thumb:
With the BCS restrictor removed, I run ~13-14psi. And yeah I'll try the rewire first actually..that way I can decide if it truly is a worth while mod. Thanks for the idea, I totally skipped over that one.
Edit: oh yeah, I dunno if this will have an impact, but I have low compression on my 2 driverside cylanders.
180psi, 181psi, 150psi, 148psi.
A lot of the time if you have really low compression in two cylinders that are next to eachother indicates a blown head gasket. You numbers aren't crazy low, but a leakdown test will help you pinpoint the exact reason why your compression is a bit low.
Thank you, that has been suggested to me not long ago (I have a thread around here somewhere..), you're right I should check into that.
Hopefully leakdown tests are cheap, cause im fricken broke trying to play with this damn car.
I love her to peices, but damn does she want a lot :thumb:
wow I'm screwed if I have to know how to read that once I get that/once I get my dsm LOL
may have to adjust your throttle cable or something - TPS should be 100
I wonder what the girl behind notepad looks like :sneaky:
She's tight, for sure :p
And yea I saw that, I figured 99.xx was alright though, but for my next run (full tank of gas, rewired fuel pump) I'll press harder see if I can hit 100, otherwise I'll see if I can tighten the cable some.
Thanks for all the input guys, I really appreciate it.
