finished 6bolt swap
DSMjrv
352
Dec 29, 2004
corona, California
well its getting fuel to the rail and its getting spark, however it wont run, i removed a spark plug and turned her over and no mist of gas shot out the spark plug hole... so the only thing keeping me it from running is that the fuel injectors arent firing.
the red black and yellow cas wired connect to the triangle plug and the white is tapped into the flat3 plug... the same connection that worked with the last motor... so im thinking cas wiring aint the problem here...
any ideas?
also the fuel pump doesnt activate when u turn the key, only when u crank it over
