aem 6bolt swap
dsm's can fly
78
May 3, 2008
Buford, Georgia
hey dont bash me if this info is around i cant seem to find it and the little pieces i do have no real answer. i am swaping a 2.3 6bolt into my 98 gsx on a aem ems my questions are
1. with aem cant i remove all sensors except cam crank map iat tps in regardes to running the car. (for example i can remove the factory 7bolt map and the bracket with that clip that goes under the intake manifold. etc etc.?) if not true what do i have to keep to make it run.
2. since my car is a 98 how do i set up the ignition fire on the plugs (for example stock ecu i have to switch wires 2 and 4)
3. sounds stupid but i live in a emission county will obd2 plug in emissions work on a ems and can i clear codes.
thank you for any help with this i really want to finish this project.:)
