Find me these center caps!!!!
VtecvrsTurbo
654
8
Oct 25, 2005
Massachusetts
Ok guys, I have these wheels and I REALLY love them. I get them powercoated silver or black, (not sure yet) and just cant find a set of caps for them.
Now before you go and post a link to a site that has 1 used one for $60, lets be realistic and understand thats not what i'm looking to spend on these,(unless thats for 4 :D) and would like to get AT LEAST 3 from the same place. I do have one thats beat up some and wouldnt mind replacing.
I have a very special treat for someone that can find me a set for a reasonable price. "What goes around, come around" if you catch my drift. :hmm:
Here is a pic of the rim. Its a Enkei ZR1. If you can cross reference PN numbers or whatever you guru's can do, by all means do it.
And the bolts that hold it on are real, not the push on clip style. . .
Any help is MUCH appreciated!!!
Kind of looks like this, but I can't tell if your picture is domed a bit or flat.
no part number measures 2.957" in diameter Enkei Center Caps
Looks to be the same cap as above (seen under the Optional Hardware tab):
https://www.tirerack.com/wheels/Whe...ion&autoModel=FR-S&autoYear=2013&autoModClar=
This look similar but the center is a different color and a bit more domed.
CC-162 A6063 Enkei Center Caps
Edit:
This one mentions the ZR1 wheel (SKU and Enkei part number in the link):
http://www.sfxperformance.com/parts/ENKA366-0000HS.htm
These are the clip style. Try again! :p
Snowboarder, I'm going to take a good pic of the one on there. Ill see if I cant get it off and measure the width. :thumb:
That top link sure does look similar tho.
Here you go:
The lines have a faded blue tint to them.
Looks like they match the 2nd link I posted above (you can see the blue when you view the larger image). I'd guess the 1st, 2nd, and 4th links in my post are all the same piece. Any of those links should work, but if you call to order, maybe you can confirm they are exactly what you need based on pricing and color.
Found some on ebay, may not be the price you want exactly but says 4 are available.
Just incase nothing else turns up: Enkei Center Cap 2 15 16 " Diameter on Back Silver Logo 5402 | eBay
Well those do look like the right ones, but after shipping they are likd $130. PLUS they are used. :coy:
Snowboard found a set for $119 BEFORE shipping NEW. :applause:
Ill call them tomorrow and see if I can cut a deal, they do have 24 of them...
Anyone else care to challenge Snowboarder's find?! (if nobody does, you will hear from me tomorrow :hellyeah:)
Good eye man, didn't even notice. Fortunately that doesn't bother me. Shoot, if they looked totally different but fit fine, i'd buy the cheaper set.
Uh snap, did I just start something!? OMG ROFL
Well now you got me thinking! So I double checked:
The diameter on Snowboarder's find is 2.957"
Where as the other one is 2.969"
Completely minuscule but i'd double check with the company before placing an order either way.
Home Depot would have those?! Badass. Ok, nevermind on hardware. :rocks:
Thanks for that, I looked up some hardware sets and they want like $14 per cap. Dang rip-off...
Update: The ones I was going to get won't work. If you look closely, three of the five holes need to be threaded. Only two spot in the cap don't have threads (where is screws to wheel). My rims don't have five threaded holes for the screws...dammit
