Finaly got it installed
JuGs
674
Jul 20, 2008
Marshall, Wisconsin
Well few of you may know I just got a turbo rebuild. Heres a few pictures of the new setup. Its not fully installed but its about there just a few little odds and ends. Sorry for the fuzzyness but thats all I can get atm. I also put a few others for the ones that have not seen or heard of me LOL.
That turbo looks HUGE LOL. Hopefully you didnt hurt your turbo with the kinked oil line. Boost on over here and lets get mine up to par and inspected. I can see hang outs and crusies bewteen you and I. Looking forward to fun times and hanging out more
Im sure turbo is fine. Yeah I can cruse your way after I do a few more touches. I might have to get my IC piping beaded but Im going to try T bold clamps first and hope I dont blow another coupler off. Shes running good tho just need a few more tweaks.
Its awsome news on it running good. Mine is going to feel like slow as bawls compaired to yours no joke. Im surprised not too see a aftermarket hard piping turbo intake on your car.
^ that's what I was going to say. I'm surprised a compressor that large would be equipped with a small enough inlet to fit the stock snorkel.
what tuning was previously on this car and injector upgrades? I forgot if you once told me.
Prevously I have a chewed up real evo 16g. Yes IC piping is ebay. I also was running the stock IC piping with the 16g. I do have a dejon tool intake but thats on my buddys car at this time and Ill be getting that soon. Thats why Im using the stock intake pipe for now. I have to redo all the IC piping tomorrow I keep blowing off couplers. I just picked up a few T bolt clamps so I hope that holds alot better. If the T bolt clamps dont help I could use a bit of info on putting beads on the end of the pipes. I also have a ebay MBC ( not installed ) I dont think its worth using so I have to run stock boost. How much boost can I run on 450s?
heres a picture of what intake pipe I have just have to get back
T bolt clamps i buy from cat diesel services 1000% stronger like ebay .
16psi max with safc.
Ok thats what I thought. Well I thought it was either 16 or 18.
I have a non eprom so no flash. I need a safc yet then ill get injectors and eventully a AFPR also. thats all on my list along with a alluminum radiator and I think I will be set.
buy ecu from 98 dsm or 99 u can flash this i have on my 95 dsm ecu from 98 :)
i have spare ecu eprom evo injectors and safc.
Well I got it to boost without blowing off couplers. But Im not sure if the WG is working properly. Im not runing a MBC its just the WG pressure. Stock WG range from 8 to 14 psi usally right? Im hitting between 10 and 14 but 10 is more common. Im sure I have a few more leaks to fix and ###### even readjust my BOV.
Well I have no smoke. Ok I got on it hard and blew a coupler again. WG is working but not properly, was stuck open when I parked after coupler poped. Im sure its not the right WG with that said that will cause flutter correct?
That is correct. I might have to do a delete and get a external
Quick question I didnt think I needed to start a new thread for. I was talking to a buddy of mine and he say Im not in need of a tuning device? I told him I do need one and he says what for your using stock injectors. Im sure I do but I wanna get more .02.
  • Wanted 6 bolt NT water pipe
    • chrisman287
