finally installed my fp2's , sbr manifold
spydur8385
45
Jun 21, 2006
NC, North Carolina
For your viewing pleasures... I installed my fp2's , 3g lifters which i think might be bad , i'm hoping they quiet up some after I put a load on them. (in person you can hear them over the open exhaust) I also installed my sbr/hafe manifold now I need to do some fabwork for my external gate , I have the new tial mvs vband and I have a 38mm flange and I have some tubing coming from vibrant , I will be adapting a 38mm flange to a vband then putting the mvs on there , will probably have to get a slimline fan as well. Also guys on that startup video I have there anyone know why my car has startup hesitation almost as if the battery is not providing enough power , or firing order is off, I didn't have this problem till i did this cam swap.
4g63 fp2 camming - YouTube
4g63 fp2 camming rev - YouTube
4g63 fp2 camming startup - YouTube
i had the exact same header with a 2 bolt 38mm tial, it will sound loads better with a wastegate on there:thumb:
did you pay the extra $65 to have it ported?
those fp2s sound awesome;)
No I got it used , but from what I have read is sbr/hafe/bep took an evo 3 manifold ported it , added the wastegate flange and cast-ed it.
its a possibility, if you notice on it the flange is angled towards the radiator allowing you to run a larger turbo without having to dent the water pipe:thumb:
there is a significant difference in spool time, i hope you enjoy it:)
Were the lifters brand new/properly bled?
It took my 3G lifters about 2-3 full weeks for them to finally shut up.
