Finally got the intake and exhaust so what next???
Wilfus65gs
150
Feb 20, 2004
Marion, North Carolina
I finally got my intake (k&n filter with stock pipe) and my exhaust (custom piping from cat back with magnaflow muffler) and i was wondering what i should do next. I was thinking either a computer upgrade or underdrive pulleys but i dont know which ones are good. Any help or other suggestions would be great.
DSMSpyder99 said:
i would say:
replace the cat with a hi-flow or straight pipe
get a header
underdrive pullies
bigger throttle body
Click Here
It is an underdrive pulley.
But yes 1) Get a Hi-Flow Cat 2) Get a header 3)af/x UDP 4) get a wideband o2 sensor and a a/f guage b/c after those mods i was running rich so i decided an afc was needed 4) Jusst port your own tb to 55mm then you will start heading into some serious modding ie p&p intake manifold, p&p your head, cam gears, cams etc etc. Maybe nitrous LOL, internals etc etc.
There is a tuning guide on this site, i think u might find it helpful
EDIT: whoops the guy before me was nice enough to get a link, than :thumb: ks
Dollar for dollar, the one BPU you will notice the most will be the UDP. It's $140 or so from Howell Automotive. I'd suggest getting that first. After that, look into a nice header. Check the sale/wanted forums and maybe pick up a used one for cheap. I got my mint condition Pacesetter 4-2-1 for $60 from a guy going turbo. After that, start thinking about what your goals are for the car and go from there.
GSGoinFast said:
http://www.howellautomotive.com/How...duct_info.php?cPath=142_38_84&products_id=298
theres the pulley, good mod... just make sure you tighten the belts really tight, otherwise you get annoying squeeking!!! :mad: :cry:
http://www.dsmtuners.com/forums/showthread.php?t=123165
theres the tech article i wrote, just to let you know what your getting into.
i was just in your position, i had exauste, and a CAI, the next thing i did was that UDP... then after that... Nitrous :cool: that stuff is like sex!
u said nitrous is like sex...well ive got 113k on my bottom end....how much would i be able to use....and how long would i be able to use it before it blows my motor????
it doesnt matter so much how many miles are on your car as it does what condition your engine is in. if its in great condition, and your compression is good, then you should be fine. if the engine is beaten to death, you might have some problems...
now with that said, you can supposedly use a 75 shot on our engines. i am not that brave so i thought i would just play it safe with a 55 shot. well the first day of having it i craved a little more so i bumped it up to a 65 shot. i dunno if im gonna kick it up to a 75 or not. but nitrous doesnt ruin engines, its improper use that ruins engines. use it right, and use it safe, and you should have some fun.
hmmm.... if nitrous is like sex, i wonder what it is like to do both at the same time. That would be interesting... OMG
that would take some talent
