Finally a log for my car!
re-rx7
349
Jul 19, 2011
ardmore, Oklahoma
This was for a 2nd through third gear pull. ALot of you were asking for one and this one is for my final as close to no knock tune.
I can email anybody the ful page just cant get it to post. 120 is a high IAT? Coolant temps are acutually 200 flat scaled. So thats about right. Didnt have much room 2nd gear started at around 5000 rpm's. What are good IAt's?
Doesn't look horrible except for the coolant temp and IAT's.
There's no wideband logged, but the target AFR's seem to be around 10.2:1, which is fine.
WB shows 10.9-11.0 thru the whole run. Would a fmic help things? Im on a Hahn big smic with a T28 pushing 19 psi. The coolant temp arent you supposed to read the scaled version which reads 203. Is that still warm? Secondly is the IAT before or after the turbo?
If the wideband show around 11:1 then you have some airflow configuration to do.
I'm not familiar with EvoScan, so I'm not sure what's to be read.
YEs it reads right around the 11.0 mark. Airflow configuration? PArdon me, but i have someone do the tuning for me. At this pt im almost tempted to do it myself. Overall do you think this was a goodjob?
Then, stay with me here, how can i get this thing to like timing? I know the Iat sensor is in the maf. So maybe some heat management? I have all the shields on minus the 02 housing. Thanks for your help.
