FIC 650's install problem
drag97GSX
41
Mar 11, 2004
Wichita Falls, Texas
Just installed my FIC 650's and did everything by the book. Set the SAFC-2 at -30 all the way across and cranked...didn't start. Set the AFC to -18 all the way across...didn't start. Zero'd out the AFC...wouldn't start again. Primed the fuel pump like the Chiltons said before i ever tried to crank. Thought maybe i was getting no fuel pressure so i backed out the bolts on the fuel supply line...started hissing and spitting fuel as it was loosened. So i know i am getting fuel to the rail. Loosened the rail gradually with the supply line fully tightened and the tops of the injectors started spitting fuel as they were loosened. My question is are the injectors actually squirting fuel? Took one out and smelled the bottom and didn't really smell any fuel. Do I need to take out the little blue rubber inserts in the top inlet of the injector? The factory ones had no such rubber insert. If I do, what would be the best method? Thanks in advance for any help.
On my brother's 1G, it has Evo 9 560cc injectors and the idle correction is at -31. I know 2Gs take it differently, but maybe 650s may be too much. Someone else with experience in your situation may have better input
Turns out I forgot to re-hook the crank position sensor when i went fishing for a fuel rail spacer when i dropped it below the manifold....sigh...i'm such a moron sometimes. :toobad:
ROFL I was going to post, are you sure you plugged everything back in electrically but thought to myself, Im sures he's made sure of that as it looks like he's gone over the obvious things, guess not :D
Well atleast it was a simple fix :thumb:
