Resolved FIAV - ISC ? Hoses missing from Throttle Body
rnitto
40
5
Aug 2, 2013
Morristown, New Jersey
The talon I just bought has two things I need to fix:
1) Idle surges a lot once it's warmed up (1,000-1400 rpms back and forth)
2) VERY Rich in low rpms (in the 10's until boost hits) even taking 30+ % fuel out.
I noticed that the two hoses below are NOT on my throttle body. I just see the two nipples there. Thinking this is causing my symptoms. Any thoughts?
Thanks for the reply! I will start with reconnecting them. I know the previous owner eliminated a lot of stuff like the AC & ABS so I want to compare what is left in my engine bay.
Found a diagram showing where the FIAV hoses go for anyone else who may have the same concern.
I confirmed that the previous owner did perform the FIAV block off. Looks like I have a bad ISC due to my testing below:
Just logged the ISC at idle and it goes from 90 to 0. I tightened the BISS screw a bit to get my idle down from 1500 to ~1100 and the ISC stayed at 0. The terminals on the ISC all checked out at around 39-40ohms, but it looks like something is broken inside the ISC.
So hoping a new ISC will bring my idle down to normal.
