few easy questions 1g throttle body on a 2g
my97mitsGSX
248
Nov 13, 2003
Somewhere, New Jersey
when swapping to a 1g throttle body on a 2g, the sensor with a little peice of metal coming out, do you not plug in anything there? i have the ISC and TPS hooked up. There are no wires in my harness to plug anything into there.
Also, on my 1g water neck (6bolt swap), there are two sensors it seems, one sensor has two tabs/pins sticking out (i'm guessing that's either temp or a switch).. I believe the wires from the 2g harness that plug into it are black/white & black...... and another sensor with one tb sticking out doesn't get a wire?
thanks for your help
no that sensor is not used on a 2g
there are also a few fittings on a 1g water neck that go un-used when installed in a 2g
alright cool - i put a little mark on it to know its not to be used incase a year later I look at my car and notice nothing plugged into it and freak out..LOL
I have the MAP sensor plugged in, but its just laying around in the engine bay since my 1g intake manifold doesn't have a spot for it.
I'm also going to remove the EGR system.
Does anyone know which sensors on the water neck are used and not used?
Thanks.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
